will not spin or drain
last night i started a load of landry and when i woke up this moring the washer was still half way fill up with the dirty water in it . when u put it on spin all it does is hum a little but that it what can it be
Hi.
Take off the front panel and check if the drain pump is running.
Check all the drain hoses and the sump.
Most likely there is a clogged drain or pump.
For further assistance provide complete model number.
Thank you. Post the results.
thanks for the advise i found the clogged hose thank you again
You are welcome.
