My washer fills up with water,but won’t spin or drain water.It also has a burning smell to it when it stops filling up with water.And makes a humming noise.It jumps my breaker also.
— Begin quote from rosieco;392084
You might have a clog in the pump, just pull off the outer panel and check. If ok, you probably have a bad motor and/or timer.
