Wire connections for 486752 on Thermador RDF30QW
My ‘486752 Bosch/Thermador Range/Stove/Oven Timer’ was removed from my oven by someone that did not tag the wires that plug into the Timer. There are 9 plugs on the back of the timer labeled E1 thru E9. The plugs are not in order (ie E6 is not next to E7). Each plug is also labeled with another identifier (eg COM, NO, BR, L1, …). There are 9 wires plus the plastic multi-wire unit sticking out of the stove.
Can anyone tell me the color of wire that matches to each of the 9 plugs? Or how to determine this?
Stove is Thermador RDF30QW.
Appreciate any help!
Hi.
In order to answer your I need to have a serial number of the unit.
Simon.
Serial Number is 82060036
hi.
This is what I was able to find out (sorry the diagram is very bad quality).
COM - 2 wires (one to the door switch, second is a jumper to L1)
NO - 20 to up switch
BR - 3 to broil element
U? - 5 to thermal cut out
BA - 4 to bake element
L1 - 17,41(jumper to COM)
NEU - 2 wires neutral
GRD - 12 ground wire
NC - 10 to NC of the top latch switch
The multi-wire plug is attached to the disconnect plug at the clock.
Post the results.
Simon.
