Wires Burned at Timer - Frigidaire Electirc Dryer
Hello and thank you in advance for any help/insight that can be given.
Dryer suddenly stopped working mid-cycle (was set for 60 Minutes, stopped with 40 remaining) earlier today/yesterday, 12/27/12. Chassis seemed unusually warm even for having been on High Temperature setting. Turned off breaker(which had not tripped), unplugged the dryer, turned breaker back on, and checked the outlet which was fine. I let the dryer cool down then inspected internally, first the door switch which tested fine for continuity. Opened the control panel to check the wiring and found the Red Hot wire from the terminal to the timer scorched, and the corresponding Red Hot from the timer completely burned and frayed. Terminal checked out fine, so I stripped the wires back and reconnected them, plugged the dryer back in… nothing. Any ideas on cause and solution? Thanks!
Hello,
Very likely the timer is the culprit. It can be caused by a loose connection.
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-frigidaire-fer641fs0.html
— Begin quote from Gene;791295
Hello,
  • The timer [part]131719100[/part]
Here are the breakdown diagrams and Parts for Frigidaire FER641FS0 Dryer - AppliancePartsPros.com
Gene,
Thanks for the quick reply and help, both are very much appreciated. Happy New Year and thanks again!
Kenneth
You are welcome Kenneth. Happy New year to you and your loved ones!
Keep us posted.
