I have a dishwasher that’s a few years old and was sitting in my grandmothers house for a couple of winters with water in it. The first problem I noticed when I hooked it up was Part Number: AP4366628, the inlet valve was cracked. I used one from a kenmore that said it was 120volts, where the whirlpool part doesn’t list voltage at all. It didn’t kick on so I powered it manually with from a wall outlet / spliced extension cord and it kicked on fine, I let it run a full cycle with no leaks.
So before I order this replacement part I would like to be sure that there are no other problems with the control board. I was only reading 100volts out of the connector to Part Number: AP4366628 so I’m assuming this is why it wouldn’t power the Kenmore one. Can anyone verify this?
Thank you.
