The dishwasher stopped running water. I pulled off the connector to the water inlet valve and when the dishwasher was supposed to be filling, the voltage moved around from 6 vac to 12 volts vac. It didn’t drift rapidly but it for sure was changing. I bailed water into it by hand to let it run through the cycles and suddenly the voltage was 125 vac. I reconnected it, and it ran to the end. I put the dish washer back in place and it seems to be working fine.
I really don’t want to disassemble a working dishwasher to trace the wires. Any ideas where the voltage comes from on the solenoid?
