I have a GE WCVH6800J0MS front loading washer. It will not fill with cold water, only hot. Rinse cycle will not work at all, but I believe that is cold water only but I may be wrong.
I checked the water supply. All is well. Ran the cold into a bucket with good flow. Checked the screens on the inlet valve, nothing blocking them.
From what I have read, it looks like the inlet valve? What can I do to check that? Any ideas. What else should I try?
If I switch the hot and cold line around, should it then fill with all cold and no hot?
Thanks for the help
