O.K. I have a whirlpool Electric Dryer at first it was coding E1 so I changed out the Thermal Mister fixed the coding error but wouldn’t heat up. so I changed out the Heater element and the Thermal Cut-Off. Still is not heating up so i changed out the Thermal Fuse. Its still not heating up what else is there that could cause the problem?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GEW9868KL0
First I would check the power.
Use the 750 volt AC scale.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Unplug the unit.
Using the lowest scale on the meter (usually 200 ohms) measure from the red wire on the thermal cutoff to the red wire on the heater.
Should be in the 8 to 12 ohms range.
Check the thermistor. It should be about 10,000 ohms. Use the 20 K scale (20,000 ohms)
If both are OK you will have to do a live test.
Be very very careful.
If you are uncomfortable doing this get a friend who has electrical experience or a pro in.
Unplug the red wire from the heater.
Make sure that it cannot short to anything else while you do your test.
Plug the unit in and start a heating cycle.
You should see 120 volts between the heater connector and Neutral/ground/heater case.
If not then the control board is probably bad.
If OK.
Measure from the red wire you disconnected to the heater case.
You shoul also see 120 volts here.
If not there is a problem with the centrifugal switch on the motor.
Unplug the unit and check the wires at the switch.
It is not that uncommon for one of them to come loose.
Also check that the motor is clean.
If all OK then the motor is probably the culprit.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
