won't spin or wash
HELP! :eek:
My front load washer will fill and drain BUT won’t spin or wash.:confused:
Tim
Tim,
Remove the bottom access panel and check for an envelope with the tech sheet. Perform the troubleshooting as described in the tech sheet.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5159284
Also check behind the access panel under the dryer.
