wont spin out
It will not spin out. It has been getting where it was leaving the clothes wet so would to run it thru a couple spin cycles. Sounds like the motor is rnning but just wont move. HELP!!
Does it drain? Have a look under the machine in the front center. Do uou see anything resembling ground white plastic, and/or pulverized black rubber?
What you describe sounds like a possible broken motor coupling (a relatively easy fix).
AP3963893
