wont spray dishes
My dishwasher stopped spraying the dishes. The water comes up through the bottom sprayer but its like it does not have enough pressure in order to spin that bottom sprayer. The water does not come up through the top sprayer either.
Hi.
First check if the water level comes up to the heater, then check the wash arm jets for restrictions (clogs), then check the pump filter [part]8519553[/part]
Clean if needed.
Here are the breakdown diagrams and Pump and Motor parts for Whirlpool DU943PWKQ0 - AppliancePartsPros.com
Simon.
The water level is not up to the heater.What does that mean?
Hi.
The screen inside the water inlet valve may be clogged.
Still check everything ells.
Simon.
I guess I dont know where the inlet valve is? Could it be the pump motor? I think I have checked that valve and its not clogged.
Hi.
Here is the water valve 8283345
It’s located underneath of the dishwasher on the left.
But first check the pump filter.
Simon.
