Yet another ND error
Here’s my info:
WASHING MACHINE MAH6700AWW
Serial Number 184654ALA27091Z
I’m getting the ND error-
I’ve replaced the pump and cleared out the hoses
I also replaced the drum belt
still getting the error…
I’m guessing it’s either the "Water Level Pressure Switch" or the "Control Board"
Is there anyway to test to make sure either are not working?
It’s an intermittent thing but seems that if I don’t have any laundry in the drum it can actually finish the program. Very frustrating, seems like the Boards are failing pretty regularly and they’re out of stock in most cases.
Thanks in advance of any help you may provide!
Mark
It sounds more like the control board than the water level switch, and the control board is sufficiently expensive that it suggests replacement of the machine rather than fixing it.
However you can try replacing the water level switch and if you order it from this site you can return it if it does not solve the problem.
I have not tried that… I look at the control board and it has a few small signs of burn in/out. Some brown spots and melting of the gel that surrounds the components. I couldn’t buy a new board if I wanted to - they seem well back ordered…
I will put serious thought to buying the sensor!
Thanks for the thoughts, please let me know if you or anyone else have any others…
Mark
If the board has burned spots it is almost certainly the board. Time to get a new machine, a basic top loader with no electronics is what you want.
