80 series washer doesnt work
The washer would fill, agitate and drain but would not spin. i have replaced the motor coupler per pro advice and reading the problem descriptions. I have inspected the clutches and they do not seem to be worn excessively. After replacing the coupler the machine now will not fill, will not agitate and when set to spin it moves just a little and stops, and every 30 seconds or so it moves a little and stops again. It will move in the rinse cycle but no water and still very weak and can be stopped by hand and very slow to start moving. I have checked power to the water fill solenoids and get no power. It filled the first time after replacing the coupler but that was all, and would still not spin. There is line power to the timer, but shouldn’t i hear the timer running? It makes no noise at all. Is my timer bad now? Seems odd that replacing a motor coupler would suddenly create all these other problems.:mad::confused:
