Access & Removal of mixing valve
How do I access and remove the mixing valve: rear panel or top? :o
You have to pull the washer out to gain access from the back and from the front. Remove the front panel. Remove the screw on each top corner holding the top panel. Remove the screw holding the valve bracket on the back.
  • The part number for the mixing valve is AP81660
Here are the break down diagrams for the Amana washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=714438&&model_id=17457
