Admiral Washer Spinning Issues
Hello Everyone,
We bought an Admiral washer four months ago (model #ATW4475VQ) and have developed an issue at the spin cycle. After agitation and draining, the washer fails to enter the spin cycle. You can hear what sounds like water filling and then that stops and it just sits there making a humming noise. Upon opening and closing the lid, it enters the cycle. I had a repair technician come in and replace the transmission and timer and the problem remains. He informed me that after it drains, it begins to spin slowly and fill slightly with water. After the water stops, the speed picks up into the spin cycle. I’m not so sure this is correct. The washer didn’t do this when we first bought it. I’m sure it’s not the lid switch because it drains properly and everything else works the way it should. Any help would be greatly appreciated. Thanks!
It sure sounds like an intermittent lid switch problem, but you need to get the Maytag techs back out and tell them to fix this thing. Part of what you paid for was a warranty, so get them to honor it!
Good luck.
