Admiral Washer - where do I hook the counter balance spring???
I posted this on the product page but didn’t receive any additional help from the response that I got [http://www.youtube.com/watch?v=pgjir05aBp0](http://www.appliancepartspros.com/whirlpool-spring-285901-ap3176818.html"]Whirlpool 285901 Spring - AppliancePartsPros.com[/URL]
[COLOR=#0066cc]I ordered this spring to fix the problem with my washer banging against the front of the cabinet when spinning, however I can’t seem to find where this spring connects to on the spring bracket (Item# 64067) that I recently replaced. There are no holes in the spring bracket nor do I see any existing holes in the bottom of the base frame assembly. I watched the APP video to replace this spring but the spring bracket seems to be different than #64067. The spring bracket in the video seems to be a bit longer on the right side with a hole to accommodate the counter balance spring. Please help![LEFT] [/COLOR][COLOR=#000000][/LEFT]
[/COLOR]
Here’s the response that I got: [LEFT][COLOR=#000000]Answer[COLOR=#0066cc]285901 Hello 808casher, The part that your ordered SPring is the counter balance spring. Here is a link that will tell you how to install the spring. [URL="http://www.youtube.com/watch?v=pgjir05aBp0) [/COLOR][COLOR=#000000]
[/COLOR]
[/COLOR]
[/LEFT]
I’ve already watched the video and explained that the bracket in the video doesn’t match up with the bracket that I had purchased because it doesn’t have the holes to connect the counter balance spring. So what am I to do in this case? Please advise. Thank you!
