— Begin quote from denman;743826
They have to be frosted up to the point that the evaporator fan cannot pull air through them.
See the attachment for the tech sheet. It has info on how to force a defrost cycle etc.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
Manually force a defrost cycle see the tech sheet. When the fans and compressor turn off you are in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the defrost board (Item 9 in Section 10) needs replacing, re: it is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 25 in Section 4) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 10 in Section 4) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Well, two weeks have passed and the unit has frozen up once again. (see attached photo)
I attempted the forced defrost procedure and the unit just kept running.
I wasn’t quite sure of the location of whether the defrost heater was inside the freezer or inside the rear panel, so did not check to see if it was on or hot.
As you indicate, it is most likely the defrost board (Control adaptive-defrost), item 9 on panel 10 of the parts list). Unfortunately, the system indicates that the board is "not available".
I do have a meter, a Cen-Tech P37772, purchased from Harbor Freight, so if I need to further check the heating element or the defrost thermostat, I can. I’ll need to freeze the thermostat in order to conduct the test as indicated.
