I have the new replacement tub seal but it is not the same size as the original. The base of the old seal was only approximately 1/4" wide while the new replacement (36425) is almost 3/8". Any ideas on how to get it to seal on the bottom? The size around the upper shaft is correct.
Related topics
1001repair | 0 | 1276 | October 24, 2011 | |
Is seal in outer tub replaceble? | 2 | 1470 | December 18, 2008 | |
Amana washer sealant | 2 | 1322 | January 26, 2011 | |
amana washer leaking at tub seal | 1 | 2329 | August 14, 2008 | |
Mounting stem and boot seal replacement | 0 | 3343 | August 26, 2008 |
