Amana washer motor not going ccw in spin cycle
My Amana washer is going cw in spin so the drum is not turning.it should be going ccw any ideas
Sounds like a transmission issue, although it could be the timer/control. I would try changing out the timer and if the part does not work and you purchase it from this site you can return it.
I changed the timer same problem .it looks like the motor has different windings for spin and agitate .
