I am replacing the blower assembly in my dryer and also replaced the glides and felt seals as they were worn/damaged. I am worried that the bearing is bad for the drum which led to the damaged components. Is there a way I can see if the bearing is bad while the drum is off to determine if I need to replace it?
Related topics
How do I tell if the Bearing is bad | 4 | 5618 | August 12, 2009 | |
which bearing? | 0 | 1060 | April 4, 2009 | |
Dryer tearing off buttons | 6 | 3701 | December 17, 2012 | |
Frigidaire dryer noisy again after bearing replacement | 1 | 581 | September 3, 2017 | |
replacing front drum glides and felt on GE dryer | 2 | 5433 | March 31, 2011 |
