baking
All Of A Sudden The Bake In The Oven Does Not Work, The Gas Ranges Work And The Broil Works. I Think It Could Be The Igniter In The Bottom Of The Stove For Bake Any Other Suggestions. Please Help
Could be, check the amp draw if it is glowing to see if it matches the amps on the side of the gas valve, if it is not glowing need to see if it is broken or if there is no voltage to the igniter…
