Ge Gas Oven
I HAVE A GE GAS OVEN THAT ONLY THE BROILER BURNER WORKS. THE
BOTTOM BAKE BURNER WILL NOT IGNITE. IS THIS A FIX FOR A HANDY PERSON. THANKS FOR ANY HELP? :confused:
Remove the bottom drawer, disconnect the Bake igniter wires and check the igniter for [AP2014008](http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html"]continuity[/URL]. Replace the igniter if the circuit is open.
This job is not too difficult to do it yourself.
Here are the break down diagrams for the GE range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=21093424&&model_id=214203
