Approximately a year an a half ago I had the control module to my Bosch replaced under the recall. Recently the module has gone kaput again and I am pretty certain it is the heater relay circuit that is the culprit. I tried to get another freebie out of Bosch but no dice and it probably is well known by now that the replacement module is no longer available. When I took a look at the circuit board there is no clear evidence of a bad solder joint as I have seen in many online pics and vids. So…I am at the point where I am wondering if anyone knows of a retailer who may still have the part and/or another compatible Bosch control module as that is likely the only way I am going to get this fixed. Thanks.
Related topics
how do I remove control module from Bosch dishwasher | 15 | 15619 | February 10, 2013 | |
Discontinued parts? | 1 | 2047 | January 23, 2010 | |
Bosch SHU5315 UC12 control module shorted | 4 | 4215 | December 13, 2009 | |
Bosch no heat and long cycles | 0 | 3402 | September 12, 2009 | |
Bosch dishwasher control module | 2 | 3003 | June 6, 2012 |
