Broiler comes on when baking
This is a GE Built in Electric Oven. Model # JKP158W1BB
When you set the temp to say 300 and turn the oven on as it starts to heat the Broiler and take it over temp. And then you get an F2 Failure Code. I have tried turning off the Elect for 15 min and turning back on, NO help. Checked the points under the covers on the control board for both the Bake and Broil and they look good and are not stuck. Checked the top switch on the door lock and it looked OK. Checked the Lock circuit thermal switch and it is closed (N.C.) Changed the Sensor Assy WB21X5301 (long prob that looks like a bimetallic wires in a tube, thermal couple?) and that did not help. What next??? Any help would be appreciated. Michael N.
