catman
front load washer is just over a year old and out of warranty. It was in spin cycle and just shut down. No read out on display, nothing. Unplugged and plugged back in but no response. Power is at outlet. This washer gave problem about 7 months ago and they replaced the main control board but I can’t remember what the problem was. I removed the front panel but did not see any fuses on the board. Not sure where to go from here without a manual or advise. This is for an animal shelter that I volunteer with and they use it every day. Any ideas??
See if this helps.
Nat
[SIZE=4]I’m having trouble with my washer not being able to wash or rinse in cold water. Any info on parts and/or repair would be very much appreciated.[/SIZE]
[SIZE=3]Turn the water off and remove the cold-water hose from the washer side. Look to see if there is a screen inside the hose (it may be on the other end) if so clean it out. Once done point the hose into the washer and turn the water on if you have good water flow reattach the hose, turn the water back on and try the cold water. If you still do not have cold water replace the water valve. http://www.appliance-repair-it.com/clothes-washer-repair.html[/SIZE]
Note that there is usually a filter screen built into the input side of the cold water valve itself. If dirty clean it, do not remove it as it is there to keep crud out of the valve. Crud could hold the valve open and cause a flood.
Thank you for the info, will give it a shot!
I took the hose off the back and it was clogged! Thank you for saving me a service call and a headache
