Control Panel doesn't light up
We had a power surge into our home tonight and now we do not have any power to our control panel on our dryer.
Here are your parts includes wiring diagrams
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE5500AYW
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK then odds are that the control board is toast.
