The plastic panel on the water/ice dispenser control panel is suffering from my heavy finger pressure and needs to be replaced. The insert (Dispenser Facade Insert) is available (Appliance Parts Pros P/N AP4078628) but installation is not obvious from drawings. I suspect the facade part may be removable from the front and allow the insert installation without going through the back of the door. If so, I will get the part and a couple of others too. If not, however, I will just put up with it. Thanks for any help. GilP
Related topics
Jenn Air Control Panel Replacement Part | 2 | 1445 | April 29, 2012 | |
Jenn Air fridge with broken water/ice panel. | 1 | 1884 | January 4, 2013 | |
working on ice&water dispenser unit | 4 | 2050 | August 2, 2012 | |
Removing ice make with electronic panel | 4 | 501 | September 26, 2016 | |
Amana Side by Side Facade insert | 1 | 1245 | May 26, 2009 |
