The lower oven does not heat. I replaced the HTC switch, however, it did not solve the problem. Any thoughts?
If you sure there is nothing wrong with the thermal cut-off and/or wires then the problem most likely is a bad lower oven relay board.
- The lower oven relay board AP3851203
