Dacor oven won't heat
[LEFT]Oops! I posted this earlier with no title–let’s try again.
[FONT=Arial]I see this question has been asked often with no clear answers. It seems obvious this is a common failure mode for Dacor ovens, surely someone has an answer. [/FONT]
[FONT=Arial]The upper oven works fine. The lower oven won’t heat in any mode. After setting the mode (Bake/Broil) and setting the desired temperature, the display acts normally for a brief time. The display changes from Bake to Pre-Bake and the word ON is displayed and then a few seconds later the display reverts back to showing the time only as if nothing had been requested. I have reset the thermal limit switch with no result.[/FONT]
[/LEFT]
