Dacor lower oven not heating
My Dacor MCS230S lower oven is not heating. Neither the main element nor broiler will heat. The controller shows that it is on and I can hear a relay clicking on and off. I removed the thermal switch because it did not appear to be resetable with the red button in front. When I test the switch it shows that the terminals are shorted so this may not be the problem. Any thoughts on what else could be the problem?
I have had the same problem…replace the HTC switch and the lower oven still not not heat:mad:
