Any guesses what to fix when the dishwasher acts like it is unplugged?
It is plugged in and there is power to the bottom of the washer.
Fuse? Control panel?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DU1055XTPQ3
Since it is easier check the fuse (item 6 in Section 2) first. It should be 0 ohms.
If it is blown be sure to use the new wiring harness that com,es with it.
