DIsh washer starts then stops
Water will fill bottom container, the start to pump through the outlet pump but stops within a few seconds.
Any ideas?
Hi.
Did I get you correctly: the d/w fills up with water then starts draining and shots off?
Simon.
The machine will stop as dion as the pump
begins pumping water into the spray arm on
bottom. It will try to start after that but stops
at the same point once water is pumped into the
lower spray arm
Hi.
Remove the toe panel and using the multimeter check if the motor is getting 120VAC when it set to wash. If it does - replace the motor/pump assembly.
Here are the parts Pump and Motor parts for Whirlpool DU930PWPQ1 - AppliancePartsPros.com
Simon.
