Unit will not cycle. Start button does not lite. Ran diagnostic field test indicated faulty turbidity sensor. replaced still no good. lites on control panel not functioning properly. Concidering replacing control panel next. Please advise.
Serial number 34992138JN .
Hi.
The model number you provided doesn’t come up.
Please check and post the correct one.
Simon.
Simon
The model number is recognized by Jenn Air. However the serial number 34992138JN calls for a different part for the replacement cuircuit board.Hope this helps.
Gil.
Hi.
Based on the information you provided the control panel should be replaced
Here are the breakdown digrams and http://www.appliancepartspros.com/control-panel-door-parts-for-jenn-air-jdb1090aws.html
Post the results.
Simon.
P.S. The first model number you posted had JBD.
Simon:
Does the circuit board drive the control assembly or the other way around?
Is there a test to verify this is the right action? I await your advise will be gone this weekend,but will check your reply on my return.Many thanks in advance.
Gil.
Hi.
If there is no control panel test in the tech sheet, that mean it’s not available.
If you’ll get the parts from APP you may return it back thanks to our unique return policy even if you installed them.
The control panel sending commends to the control board.
Simon.
