I need to replace the dispenser cup. Do I unscrew all of the screws inside the door panel or just the lower 2? Please advise the easiest way to take off the stainless door panel to get to the cup.
Remove the access panel (13 on the [AP3841622](http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=651639&&model_id=47812"]rear cabinet break down diagram[/URL]) and check the belt.
If the belt is broken - replace it.
If the belt fall off but it’s not broken, open the door and check if the drum is moving up and down.
If it does then most likely the rear bearing is worn out and has to be replaced.
The rear bearing comes as a part of the outer tub assembly.
AP204967The part number for the belt is
The part number for the outer tub assembly is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3841622&&model_id=47812&diagram_id=692639)
Here are the break down diagrams for the Maytag Neptune washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=692639&&model_id=47812
Is there anything other than orfice change outs necessary to convert a Whirlpool conventional Range to LP gas. I was told that the regulator needed to be changed out but I don’t see why that would be necessary if the source is regulated like Natural Gas is at the meter.
The regulator does need changed but all it consists of is flipping the cap upside down
