Goes Thru The Wash Cycle Doesn’t Drain. Checked With Multimeter When Cycle Switches To Drain No Power To Valve. Changed The Computer Board Did Not Help.
Here’s a parts exploded view of your motor and pump assemblies. The drain pump is part #17 in the diagram.http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139919&diagram_id=946795#d946795
AP3865489
