Dispenser Panel no power
Dispenser panel suddenly no power. Comes back intermittently. Remainder of ice maker, refrig & freezer are working fine. Checked plug to door and appears to be OK. How to access back of panel?
Removing the (drip) tray will expose the screws that hold the compartment in place. Remove these screws, and you should be able to slide the compartment assembly up until it clears the clips that hold it on the door face. Careful–There’s 120VAC in there!
