The display on the oven slowly got dimmer until it no longer is visible. We replaced the whole cover with the power module attached, about a year ago because the unit would not work at all. This fixed part of the problem as the ovens would heat up but you stlll cannot see the display. Now the bottom oven just stopped working again. Will replacing the diaplay module have any effect on the bottom oven working, or do I need to replace both the display and the unit that came attached to the panel?
Related topics
Thermador SEC301BP Display Dim | 1 | 83 | February 11, 2024 | |
Dim display (top oven) | 1 | 787 | July 11, 2011 | |
Thermador display is very dim | 85 | 68371 | January 3, 2018 | |
Thermador oven display is very dim | 0 | 3965 | June 21, 2009 | |
Thermador display panel dim, all else ok | 4 | 3972 | July 7, 2010 |
