Thermador SEC301BP Display Dim
The display on my Thermador SEC301BP built in oven is dim. I was hoping that replacing the capacitors in the display board would have solved the problem similar to some of the older models. However, after replacing the display board capacitors, the VFD display is still dim. Other threads suggest replacing the power relay to solve the problem, but the models described are significantly different than mine. My model has a Display Board behind the touch panel and a separate Relay Board mounted above the oven horizontally. The wiring schematic also doesn’t show any individual relays that power the display board. Any help is appreciated.
