door lock switch
we are getting a fdl code for the door lock code. is there a fix or does the switch have to be replaced? Is is an easy fix and what is the part #?:eek:
The model number you posted does not come up. It can be incorrect or incomplete. Verify and repost it.
P.S. Look for the tech sheet inside the control panel. The explanation and instructions can be there.
