Drum catches clothes
The drum on Frigidaire FSE446RHSO catches clothes as it turns, causing dirt marks on laundered clothes. The drum has some play when you push against the back of the drum. The gap at the top is about 4 time the gap on the bottom. Is this an easy repair? Parts list shows a shaft with a ball hitch type end, and a bearing that mounts to the body of the dryer. Or is there more to this problem?
You most likely have a rear drum bearing wearing down, causing the space in the front of the drum. The clothes will get caught in the front, and also get black sreeks on the clothes. Tom http://www.applianceeducator.com
