Washer & Dryer combo. Frigidare Model GLTF1670AS0. I ordered a door lock switch and this did not help. I then removed the back and run some test. I have a locked drum and I cannot break it loose. Should I just trash this washer?
— Begin quote from Larry2250;793599
…I have a locked drum…
Hi Larry,
How did you find it?
Which tests did you run?
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-frigidaire-gltf1670as0.html
