Drum Turns About 10 Minute & Stops
:slight_smile: HELP!
My Kenmore dryer’s drum will start turn for about 10 minutes then seems to bind slow down and stop. When I try to turn it by hand it seems bound then frees up and will turn for a short time then stop again. I have installed a new belt, tension idler, and four new drum rollers but still have the same problem. Any ideas??? THANKS:)
Yes, I do it sounds like you need a new motor. If you want me to walk you through the repair, you can reach me at my web site at http://www.applianceeducator.com Tom
