drum turns no heat
whirlpool dryer starts and the drum turns but no heat to clothes. runs thru any cycle just no heat.
any ideas?
http://www.appliancepartspros.com/parts-for-whirlpool-leq9858pw0.html
See the attachment for the wiring diagram.
Could be a number of things but I would start with the power.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If OK, unplug the unit and check the following with a meter:
Heater - 8 to 12 ohms
Thermal cutoff - 0 ohms
HiLimit Thermostat - 0 ohms
Operating Thermostat - 0 ohms
