dryer inglis
Hi everyone! i have a dryer it’s 2 years. now she doesn’t start. yesterday i took the clothe out of her and it was all dry, but them when i was going to put another load it won’t start. can anyone help me? what can i do?
A model number may help others help you.
I am assuming this is an electric dryer (not gas).
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
Most unit use L1 to Neutral (120 volts) for the motor (start).
If OK
If OK
Do this with the heater off and on.
If the power is OK then many units have a thermal fuse.
If blown be sure to check/clean your vet system as that is the most common cause of it blowing.
Next would be the push to start switch or the door switch.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
— Begin quote from denman;664306
If OK
If OK
There is a good STICKY at the start of this forum about it’s use./
I do not know if your second post is just an error as all I see is my quoted post.
— Begin quote from denman;664355
it was a mistake
i wanted to say that my model inglis 180-00
I cannot find any info on the given model number, please check it.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Model numbers are usually some letters and then some numbers.
Looks like Inglis is made by Whirlpool.
Perhaps the following will help as they have general repair help.
http://www.applianceaid.com/dryers.html
