dryer not heating
My dryer spins but there is no heat. I dont own an Ohm meter to check continuity but i replaced the thermal fuse. After starting it up, the fuse immediately blew. Any thoughts what i should look at next? Why would a brand new fuse have blown?
A model number would be helpful.
http://www.appliancepartspros.com/modelnumber_locator.aspx
A fuse would blow right away if you have a dead short in the unit.
Note that I am not sure you are using the correct terminology.
What is normally called the thermal fuse kills power to the motor.
Could be you replaced the thermal cut-off or the high limit thermostat.
They effect only the heat.
I would unplug the unit and check the heat coil.
Disconnect both wires from the heater and measure across the heater.
Should be in the 8 to 12 ohm range.
Now check from each side of the heater to it’s case.
Both should be infinite ohms.
If not the heater is grounded and should be replaced.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Thank you for the quick reply denman. The model number is KGYS700GQ1. The part i ordered was 3392519 (thermal fuse). I am borrowing a neighbors Ohm meter today so hopefully i can pinpoint exactly where the issue is instead of ordering part i think it the solution just to have it blow. My next question is if the issue is the heating coil or element am i better off just purchasing a new dryer? Thank you.
http://www.appliancepartspros.com/parts-for-whirlpool-kgys700gq1.html
See the attachment for the wiring diagram.
Your unit is a gas unit so the fuse you replaced will just shut off the heat.
There is nota heating element in the unit.
