the dryer quit heating and about a week later the washer will not work at all. It was working great at the old place, we moved into the new place and had to put in a double pole 30 amp and run new wire, I used a 10/3 wire.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LTE5243DQ3
See the attachment for the wiring diagram.
Since you used 10/3 I am assuming this unit is a 4 wire hook up and that the old house also used a 4 wire hook up.
Is this correct or is it something else?
The first thing I would check is the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
Neutral to ground should be 0 ohms.
If OK
If OK
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
