Dryer squeals hi piche during operation
Hi all,
When I turn on the dryer it used to make a high pitched squeel during operation.
I took the top and front off and vacummed out the inside and also cleaned the back side. It worked for a little while.
Now when it is turned on the drum seems to be stuck and is hard to turn by hand.
I replaced the front felt top and bottom and it would turn on for about 1 minute or less then it makes a lot of growns and thumps then stops and I can not turn by hand very easy.
If I take off the front and just but it back on it will do the same thing each time.
Am I missing something?
