Infinity series. High pitched squeel when turned on. More often than not. Has gotten worse. Removed front and found upper felt seal is compressed to half thinkness. Could that cause the squeal? If it is the cause would removal and flipping to utilize thicker uncompressed half work?
Or would it more likely be the rear drum bearing needing lubrication? Thanks
