dryer starts then stops and makes noises
my dryer will start but after about 5 minutes it turns off. when I push the start button it makes a sound like an almost dead car battery. If I keep pushing the button the sound will eventually become a click noise and then it won’t make any noise. If I wait a half hour or so the dryer will start again. After it shuts off the motor feels warmish. Also when it first starts up, the belt squeeks but the noise goes away in about 15 seconds. I’ve cleaned the vent tubes, the drum turns…where do I start in my attempt to fix this and evaluate the issue?
thanks.
karen
The motor is your problem. The squeak could be coming from the motor. Or, it could be coming from the drum rollers. They actually have a kit that comes with the 3 drum rollers the idler pully and the belt. It is a good dryer, and is worth repairing. The motor, part # is 279827, and the drum roller kit part # is 4392065. Tom
thank you so much for your help. I 've always felt it was a good appliance so I am happy to fix rather than replace (not to mention I don’t really have the funds to replace). I really appreciate the experts available through this site. thanks again.:smiley:
never mind…persistence pays off and I figured it out. thanks anyway. k
Good Job. Tom http://www.applianceeducator.com
