Dryer Will Not Heat
MY DRYER WORKS PERFECT BUT DOES NOT HEAT . EVERY OTHER FUNCTION WORKS WELL. JACK:mad:
Sorry but I cannot find any tech info on this unit.
If it is an electric dryer the first thing to check is power to the dryer.
On most units everything except the heating coil run off of half the line (120 volts) but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
